For a single stage that is too much. Besides that you want a dual stage. Work less and is quieter. A single stage will have a hard time keeping up for most things. You should be able to get a good brand name dual stage for that price.
Kevin |
You should be able to get a 2-stage, 5hp, 50 gallon compressor for way less than $500. Here is nice unit from Harbor Freight
HF compressor In general, you need compression stages for pressure and HP for volume. Single stage compressors can RELIABLY only go to 70 or 80psig. I know ads say they will do 115psig but that is really tough on them. As compression ratio increases on a stage, the temperature goes up. Two stage compressores split the compression into much milder increases with cooling between the cylinders and everythhing lasts longer. Two stage compressors take the pressure up to +120psig which is what you need for most serious applications. You need 5hp to get in the 10cfm @ 100psi range which, again, most serious tools need. |
My two stage kicks off at 160 lb. Most two stage compressors are classed continuous run. That's what you need to run air sanders for hours at a time.
Troy |
willys-Are you sure about that price? I just looked at my HF catalog and the cheapest two stage campbell hausfeld compressor they have is $999.99 (in this book anyway).It is a 5 horsepower 80 gallon tank item90391-oxwa. They have some six to seven horsepower models for under $500.00 but they are all single stage.They also have a 7.5 horsepower 80 gallon 4 cyl. model that is also single stage but comes close to two stage performance (15.4 cfm@140 psi) for 899.99. I could be wrong but less than $500.00 for a good 5 horse two stage seems a little too cheap to me.But like I said I could be wrong.
You are probably right. I got mine as a gift many years ago and that was on sale so that is where I am getting the <$500 number. Still, HF has sales all the time and I'm sure it can be had for not much more than $500 on sale. For sure, Death should be able to get a good 2-stage for the price he quoted for the single stage.
Home Depot has a 80 Gallon, 7HP, dual stage that does 15.1 cfm @ 90 psi and 13.7 cfm @ 175 psi. It's Husky and is made by Campbell Hausfeld with 3 year warranty all for $799. I am 99% sure I'll pick one up this week.
what are the big power robbers that you need these big compressors for?? or is it just so the compressor lasts longer since it's only working half as often? |
It takes that size to keep up with a DA, or a long board . A good compressor will be classed as a continuous run, meaning it can run for hours without hurting it.
Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
"80 Gallon, 7HP, dual stage that does 15.1 cfm @ 90 psi and 13.7 cfm @ 175 psi. "
Like Troy says, if you are planning a lot of body work and doing complete paint jobs, you will need the above power. I got along with a 5hp, 60gal unit for years but, as soon as I upgraded to HVLP spray guns I noticed a big drop in performance. Spraying panels or doing lite body work is okay for the smaller compressors but, if you are going to do any major work step up the big dog... Mark |
just bought one of these for 869.00 just two hours ago
