single stage metallic paint with flattner - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2007, 12:15 AM
I dont have much experience in shooting single stage paint so just wonderin if anyone had any tips, such as avoiding peel or the dust factor, because if its a flat then i'm guessing i cant sand or buff out any imperfections?? Thanks for any advice.
Old 05-09-2007, 02:55 PM
Things to avoid
Today's body shops use basecoat/clearcot for a reason. Basecoat paint can be blended easily and zebra stripes or motteling can be "fogged in" to get it to look right. A single Stage metallic cannot be fixed or fogged once it is striped. Gun set up is critical on a single stage metallic. If the guns sprays heavy on one side, you are putting stripes in. If air pressure is to low, you can sag the paint and pull the metallic down. If you are doing a heavy metallic or gold I would suggest basecoat. Clearcoat also buffs a lot easier than color!
Buffing Out Single Stage Paint "From a Production Shop Perspective" x711 Body - Exterior 18 12-28-2006 10:27 PM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
Sanding single stage? Project87c10 Body - Exterior 6 11-05-2004 12:44 PM
Metallic Paint - splotchy look bruce-77346 Body - Exterior 1 05-25-2003 07:09 AM
