single stage metallics - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2007, 11:27 PM
mitmaks's Avatar
Last journal entry: Grille
Can metallic paints be mixed as a single stage? When I buy paint at local paint store he always asks me if I want single stage or Base/clear
Old 03-09-2007, 11:55 PM
Ranchero_65's Avatar
Yes . Metallic paint has been around long before BC/CC.
Take Care
Earl
Old 03-10-2007, 12:00 AM
mitmaks's Avatar
how do you go about color sanding it and buffing it, wouldnt that mess up metallic since its right on the top of the surface or is it?
Old 03-10-2007, 03:41 AM
you don't, what you spray is what you get. Also gonna be harder to spray then basecoat, since you have to spray the metallic even as well as keep good gloss.
If you want to do any serious amount of sanding and buffing, you are going to need to clear it, so why not just use a basecoat in the first place which will be easier?
Old 03-10-2007, 06:26 AM
BarryK's Avatar
Only thing I can add the base/clear will last much longer when metallics are involved especially.
Old 03-10-2007, 10:46 AM
mitmaks's Avatar
exactly what I was thinking. Thats why I use bc/cc system only. I use single stage only for non metallic paint jobs.
Compressor - Single vs. Dual Stage cab Garage - Tools 28 09-06-2010 05:48 PM
Single stage and duel stage air compressor? DeathByGreaser Body - Exterior 24 10-19-2005 07:33 PM
single stage or used 2 stage? zimaad Garage - Tools 9 08-04-2005 09:19 PM
Sanding single stage? Project87c10 Body - Exterior 6 11-05-2004 01:44 PM
bc/cc over single stage? Lay'nFrame Body - Exterior 1 06-04-2003 02:56 PM
