single stage white - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2008, 07:07 PM
single stage white
I'm painting a old work truck single stage white,could I add some blue pearl I have let over to it. I thought I would try something different since I had the pearl leftover.
Old 01-01-2008, 07:11 PM
yea it would probobly look good
Old 01-02-2008, 08:13 AM
tyler71385's Avatar
Jackofalltrades/masterofnone
You didn't mention what the blue pearl was. If its some sort of single stage, I don't see why you couldn't do that. But if it's BC, like I suspect it is you shouldn't unless you want to clear over the whole thing. Then you'll have to let your SS dry. Scuff with grey or gold pad, Base and Clear.
Old 01-02-2008, 12:37 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Adding a pearl powder or paste to ss will take some test panels for the "right" amount. Won't have quite the pop as a tri coat or in the first coat of a clear type job. You'll likely notice the white being a bluish shade until the sun hits it and then you'll get some sparkle. The amount just depends on the effect your after and the more pearl you add,the flatter it will look. If the ss is a urethane,you could always clear it with the pearl in the first coat or use an inter coat clear/pearl for effect and then clear like a tri coat.
Pearl needs some "space" above the base to really work nice,reason for the inter coat or in the clear.Just using it in the base ,it has no "space" and kinda just is "there".
Old 01-02-2008, 09:27 PM
Thanks for all the advice, I think I'll leave the pearl.
Compressor - Single vs. Dual Stage cab Garage - Tools 28 09-06-2010 05:48 PM
Single stage and duel stage air compressor? DeathByGreaser Body - Exterior 24 10-19-2005 07:33 PM
Sanding single stage? Project87c10 Body - Exterior 6 11-05-2004 01:44 PM
bc/cc over single stage? Lay'nFrame Body - Exterior 1 06-04-2003 02:56 PM
