Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - single vs base/clear
Old 12-19-2010, 05:42 PM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by deadbodyman
I use SS for all my solid colors
X-2 on that one. Single stage has several advantages for a novice painter. Its easier to fix imperfections, easier to cut & buff (no chance of going through the clear coat) and easier to re-shoot if you screw up. Custom effects can be done easier with BC/CC but solid non metallic colors..... I'll use single stage every time.
