Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - single vs base/clear
Old 12-22-2010, 10:20 PM
kc8oye kc8oye is offline
i've also understood it that the clear prevents the metallic from being exposed to oxygen and corroding..
also if you try to 'cut and buff' a single stage metallic, you can actually affect the metallic, whereas doing the same to a clear coat won't
