single vs. dual tunnel ram - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2005, 04:45 AM
Does anyone know if there is a significant drop in HP running a single carb tunnel ram vs a dual carb ram.Specifically I'm looking at the Weind Hi-ram for a sbc.It's offered with two tops , single or dual.My hope is I could run the single carb base and enjoy the look and HP of a tunnel ram without the tuning headaches I hear about so often.
Old 06-27-2005, 05:29 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
as long as your carb cfm properly matches the cfm of what the engine needs, a single carb is perfect
people seam to think that taking a stock 1984 camaro w/ a factory 350, and adding a tunnel ram w/ dual 750 cfm double pumpers someonhow makes huge hp gains ... that that im accusing you of that in any way
run the right size carb, and run an intake designed for the rpm your gonna see the most ..
think of it this way ... your out on vacation and you go snorkeling
you have 3 size options for snorkles
"normal" diameter that everyone uses
"tiny" .... its 1/2 the diameter it should be
and "monster" ... its a 10" diameter piece of tubing
sure youll be able to inhale enough cfm's thru the monster one if you use it ... but its not like the monster size is gonna make it any easier for you to swim better
Old 06-27-2005, 08:16 AM
E.T. divided by $ spent= Speed
Wouldn't ya get water in your tailpipe?
Old 06-27-2005, 11:28 PM
lluciano77's Avatar
Running a single carb on a tunnel ram causes severe distribution problems. You are better off running dual carbs with a tunnel ram.
Really, you are best off running a single carb on a lower rise intake.
Old 06-27-2005, 11:38 PM
JSracing's Avatar
Nitro Junkie
two small carbs would work better than one large. IMO, but I run an enderle bird catcher so I guess I wouldn't be the best to advise on this. I would think the single would have some signal problems due to where it is mounted.
Old 06-28-2005, 04:30 AM
Thanks everyone.Got an Edelbrock RPM now and it works great.Just always looking for more.
Tunnel Ram on 383 Stroker Nitromethane Engine 6 02-25-2011 08:06 PM
Big Block Tunnel Ram 2X4 Question 74NovaRat Engine 12 01-28-2005 01:22 PM
vacuum assist brakes on dual quad tunnel ram Ken Milesky Suspension - Brakes - Steering 5 05-22-2003 12:08 AM
Single plane and duel plane manifold stonedchihuahua Engine 21 01-06-2003 11:56 PM
283 tunnel ram NovaProject Engine 4 07-04-2002 07:48 PM
