single wire Alt. & Amp. meter - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2005, 02:15 PM
streetrodderdoug's Avatar
I have a single Alt with an Amp. meter. I was not aware of a real problem as I have the car down for body repairs, however I took the gages out for another reason & found the Alt. wire to the Amp. meter had burnt the connector off the gauge. The wire is a number 10 gauge which should be sufficient as I under stand and the connection was tight in that a portion of the ring connector was still tightly under the nut on the post. In view of this condition I am now going to rewire the whole car, as this car was build in 1985 with about 50,000 mile and has a home built wiring system, however I am interested in knowing just what went south in this set up. I did do some rewiring under the dash a couple of years ago, when I replaced all the glass fuses with the bayonet style fuses, however I can't understand how this could cause this. I'm also getting the feeling I should be replacing the Amp. meter with a Volt meter.
I would appreciate any answers or recommendations (I have read all the survey results related to wiring harnesses & as with everything today, it seems impossible to reduce each to the lowest common denominator for evaluation)
Thank you
Doug
Old 12-12-2005, 03:56 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If you are now running a single Wire Alternator, you will have to go with a Voltmeter. There are no provisions for a standard AMP gauge, or light in the Single Wire circuit. In the stock harness.
Or you could go back to the 3 wire after your harness repairs are complete.
Doc
Old 12-12-2005, 04:10 PM
Thank you Doc
I'm told that it would be much safer to replace the Amp with the Volt which I guess you are saying would make any of the harnesses work?
Thanks Again
Doug
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Correct Alt Amp gazrnr Electrical 2 09-18-2005 08:45 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 04:22 PM
Single Strand Steel Wire in a Ranchero RAW Electrical 3 10-03-2002 02:08 PM
