Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Six Shooter disapointment Hope the Barry Grant guy is watching
  #66 (permalink)
Old 09-30-2008, 07:39 AM
spinn's Avatar
spinn spinn is offline
Originally Posted by Tech @ BG
Not at all but that is a BASIC function of setting timing. Why do you think the vacuum has to be disconected prior to setting it? Our base timing recommendations are with the vacuum disconnected as our anyone elses.
top- this isnt body work, chopping up hotrods to make things fit. its a precision calibrated component. the recommended carb could NOT adjust to my idle calibration. my engine doesnt need 18 intial mechanical timming. that would hurt driveability and the vacuum advance's ability to alter timming for part throttle power. 18-20 inital will be hard starting especially hot.
i should have built my engine around your carb. that was your real recommendation.
