Six speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2008, 04:28 PM
Giverhell and hopefer the best
Six speed?
I was wondering if a there is a six speed trans that will bolt behind my 355. This way i can have a good low first gear but can stand to drive it on the interstate if need be. If i cant find one of these then i was thinking five speed out of a 80's chevy half ton. It will go in to a 86 chvey blazer. And 4.11 gears. What yall think? And thanks fer the input
Old 08-26-2008, 04:53 PM
DeathRattle's Avatar
Some Punk Kid
Richmond and tremec both make 6 speed trans....but unless you have 3 grand go to the junkyards and find that bowtie 5 speed
Old 08-27-2008, 12:14 AM
staleg's Avatar
Last journal entry: Hand brake
T56, 6 speed transmissions from LT1 motors fits directly to your 355.
If it has 2 piece rear main seal you must buy a special flywheel. 1 piece rear main seal flywheel is ok.
But the LT1 6 speeds are getting harder to get now maybe(?)
T 56 from LS based motors bolts on with a special adapter, after what I've heard.
Old 08-27-2008, 08:28 PM
Six speed/
Thanks yall. I will check the site but if it is really that much then a 5 speed will work. I was just wanting to maybe do something diff. But a 400$ 5 spead sound alot cheaper and quicker
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 07:44 AM
what does a speed censor do? notmrgoodwrench Engine 1 06-15-2005 05:27 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Stall Speed? drlindz Transmission - Rearend 2 08-25-2003 02:40 PM
difference in 2 speed to 3 speed auto? HemmiGremmie Hotrodders' Lounge 2 12-17-2002 05:31 AM
