six speed overdrive trans for a 1980 vette - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2011, 03:33 PM
vcb vcb is offline
hi
has anyone knows what would be the best six speed overdrive trans for a 1980 vette
thanks
v
Old 05-08-2011, 05:39 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
You are going to have to provide more details to get a decent answer....
K
Old 05-09-2011, 01:09 AM
vcb vcb is offline
what info you need?
Old 05-09-2011, 08:32 AM
302 Z28's Avatar
Tremec T56, but you may have to convert your clutch to hydraulic, if it's a standard.
Vince
Old 05-09-2011, 10:39 PM
vcb vcb is offline
I have an auto 350, and will we are putting a 383 with 671 on it
Old 05-11-2011, 01:34 AM
Richmond. Uses stock clutch, comes with a shifter, wide choice of gear ratios, but pricey since you don't see many used ones.
T-85 3 speed overdrive need kit Footstomper Transmission - Rearend 1 05-07-2010 08:54 PM
new guy 1980 vette sstarling1 Transmission - Rearend 3 09-12-2009 12:59 PM
GM 11 4 speed manual trans with overdrive dan ball Transmission - Rearend 0 07-23-2007 05:26 PM
1980 Vette, any thoughts? frankenstang57 Hotrodders' Lounge 28 04-09-2005 01:35 PM
engine swap 1980 vette JERSTONES Engine 2 09-17-2002 08:26 PM
