Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - size differance GM 350 and LS1
Old 03-13-2009, 02:22 PM
iceman36's Avatar
iceman36 iceman36 is offline
I have a setup / replica GM 350 long block, with tight fit headers and transmission. But the vehicle Im building is getting a LS1 engine. I am just finishing up the front suspension and Im mounting the R&P. The question I have is if I used the 350 to check for steering shaft angle and clearances would the LS1 be that much different and cause problems? I have about 3 below the 350 oil pan and at least 1or more on both headers to frame.
Also does anyone know the difference in weight between an installed Iron and Aluminum ls1 not including Trans?
