-   -   size differance GM 350 and LS1 (http://www.hotrodders.com/forum/size-differance-gm-350-ls1-154935.html)
iceman36 03-13-2009 02:22 PM
I have a setup / replica GM 350 long block, with tight fit headers and transmission. But the vehicle Im building is getting a LS1 engine. I am just finishing up the front suspension and Im mounting the R&P. The question I have is if I used the 350 to check for steering shaft angle and clearances would the LS1 be that much different and cause problems? I have about 3 below the 350 oil pan and at least 1or more on both headers to frame.
Also does anyone know the difference in weight between an installed Iron and Aluminum ls1 not including Trans?
richard stewart 3rd 03-13-2009 03:22 PM
Hi,
Hope this two links help.
Rich
http://paceperformance.com/index.asp...=Custom&ID=586
http://www.funco-motorsports.com/v8_comparison.htm
