size differance GM 350 and LS1 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2009, 02:22 PM
iceman36's Avatar
I have a setup / replica GM 350 long block, with tight fit headers and transmission. But the vehicle Im building is getting a LS1 engine. I am just finishing up the front suspension and Im mounting the R&P. The question I have is if I used the 350 to check for steering shaft angle and clearances would the LS1 be that much different and cause problems? I have about 3 below the 350 oil pan and at least 1or more on both headers to frame.
Also does anyone know the difference in weight between an installed Iron and Aluminum ls1 not including Trans?
Old 03-13-2009, 03:22 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Hope this two links help.
Rich
http://paceperformance.com/index.asp...=Custom&ID=586
http://www.funco-motorsports.com/v8_comparison.htm
fastest muscle pre 1970 81elcamino Hotrodders' Lounge 86 01-19-2009 04:53 PM
LT1 Question DV8 Engine 10 01-07-2007 11:59 PM
LS1 heads on SBC 350? Booney914 Hotrodding Basics 5 10-03-2004 09:37 PM
