Size difference between BBC and 460 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2007, 09:16 PM
junkyardjeff's Avatar
I have seen a BBC in a 37 chevy p/u before and its tight and since I have a extra 460/C-6 I would like to put it in my 37 chevy p/u since I have it and it was a hell of alot cheaper too so does anyone know if the 460 is about the same lenght and width of a BBC. Its probably overkill for such a light truck but it would be fun,if I remove the 235 I will most likely do a smallblock of some kind but if the 460 is no larger then a BBC then I wil use the 460. Jeff
Old 03-02-2007, 03:35 AM
Guy Hiltz's Avatar
You can go to www.carnut.com and check there,they might have the specs you are looking for.
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
