size of the engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2003, 09:01 AM
size of the engine
are 305 and 350 the same size i length and with need help
Old 09-22-2003, 09:17 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
They are the same physical size.
I see you are in Duluth mn. I`ve been to the world of wheels show there a few times, dang it was clod.
Troy-Curt
Old 09-22-2003, 09:22 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Heres is a site with the dimension's for all motor's.
http://www.geocities.com/MotorCity/T...62/engine.html
Luv the smell of NITRO in the morning.
Old 09-22-2003, 10:01 AM
so there is no differents in dimensions on the 305 and 350
Old 09-22-2003, 10:07 AM
troy-curt's Avatar
Yep all small block chevys are the same size on the outside.
Troy
Old 09-22-2003, 12:05 PM
is there any way the factory could of put a 350 in and not a 305 like the vin says? because it has tones of power. every one i talk to says they cant belive that the vin says it is a 305. because i can some the hell out of my tiers
Old 09-22-2003, 01:08 PM
troy-curt's Avatar
Some one may have changed it. Check the little pad on the front of the block,passenger side,where the head meets the block, This will tell you what size it is.
A 305 will smoke the tires with the right gear ratio.
Or if the tires are old and hard.
HTH
Troy
Oh, and please use the spell check, it makes the post easier to read. Thanks.
Old 09-22-2003, 02:56 PM
where is that pad on the block
Old 09-22-2003, 03:32 PM
Right in front of the passenger cylinder head, probably behind your alternator. Its a little flat spot with some numbers stamped in it. Get the last 3 digits and go to this site and match them up to find out what engine you have. http://www.nastyz28.com/spmenu.html
