-   -   size of nut below pitman arm (http://www.hotrodders.com/forum/size-nut-below-pitman-arm-13019.html)
CHEV66JB 05-31-2003 04:41 AM
Hey all,
I'm trying to remove the pitman arm on my '66 Chevelle, and the nut size is HUGE. I tried a 1 1/4" socket and it was too small, then tried a 1 1/2" socket, and it's too big.. Is this bolt metric? Or is it just 1 3/8"? I don't remember seeing that size at the store.
Thanks in advance,
CHEV66JB
troy-curt 05-31-2003 05:00 AM
Sockets and wrenches come in 1/16 incuments (???)
some in 1/32
johnnymopar 05-31-2003 06:26 AM
easy way is to get a vernier and measure the nut. i always got stuck on the big ones, now i measure first and i know right away if i have the correct socket.
JB
superrodder 05-31-2003 09:01 AM
:p my guess is if you are laying under the car,looking up at the pitman arm then you would be the LARGE NUT UNDER THE PITMAN ARM :p
Just kidding :D
If you cant find a socket the right size at a hardware store then you'll have to go to an automotive store or tool truck.
pitman arm nuts can be torqued on pretty tight so use a large impact wrench or a long johnson bar to break it loose
CHEV66JB 05-31-2003 11:42 AM
Thanks all for your input- and yep, I was talking about the NUT one size DOWN from the one lying under the pitman arm!! 8^]
Got the nut off with a 1 5/16" socket (had to go up to 3/4" drive, never had those before!), then couldn't get the blasted pitman arm off. 40 yrs sure makes for its own form of epoxy!! Ran to the local Auto Zone, picked up a pitman arm puller, and voila!! My '66 now has a new front end!
Now, if I could just find a damn tool to shut the rain off for 2 days STRAIGHT so that I could get an alignment!!! (on the East Coast, I think it's rained non-stop since St. Patrick's Day.)
Thanks to all who contributed to this topic- this site rocks.
CHEV66JB
