Size of rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2006, 09:09 PM
Size of rear end
How do measure the size of the rear end?
Old 04-17-2006, 11:09 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Size of rear end
If you are talking about width then you should be measuring it from flange to flange. If you are talking about the center section size here is a link to a Hot Rod magazine article that talks about and gives descriptions of commonly used rear ends:
http://www.hotrod.com/techarticles/48618/
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-18-2006, 12:29 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
If you mean the common terms like "nine inch rear axle", the measurement is the diameter of the ring gear. In general, the larger the ring gear the stronger the axle. GMs typically go by the number of bolts in the rear cover, but the same applies -- a 10 bolt has a smaller diameter ring gear (7-5/8") than a 12 bolt (8-7/8").
That HR link has the best info, but missed the AMC axles. AMCs use a Model 15 (AMC 15) and Model 20 (AMC 20). The AMC 15 has a 7-9/16" ring gear, the AMC 20 and 8-7/8". The 15 has a plug in the rear cover, the 20 doesn't. That makes them pretty easy to tell apart. All AMC axles (with the exception of some Jeep models) have a two piece hub and axle with a large nut on the end holding the hub on, similar to a front wheel drive car. That's their main weakness! That nut has to be torqued to 250-300 lb/ft or the hub could spin on the axle. The key really doesn't matter, that's just to keep the hub in alignment when reinstalling after it's been removed for bearing replacement. There is no re-torque interval, but AMc never intended the cars to last more than 10 years. The last AMC axle was made around 1988, the last year of the Eagle and big Jeeps, and a few were used on some Commanche trucks. The center section and differential, however, are still produced by AM General for the military Hummer -- it's that tough!!
Old 04-18-2006, 03:50 PM
73oldsman's Avatar
This may help...http://novaresource.org/axle.htm#Dimensions
Old 04-19-2006, 09:26 AM
machinist & fabricator
i use a tape measure and a set of vinear calipers to measure rearends!
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
