Size wheels and tires? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2010, 09:00 AM
I have a '32 Ford Tudor , full fendered on a TCI frame with independent suspension and wonder as to the size of wheels/tires to run? I would like to run 15", but this is not etched in stone. Any help or info. would be greatly appreciated.
Old 12-19-2010, 01:40 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I am running 15" a 275/60 r15 rear and a 205/60 r15 front but then that is my choice..But then I do not have the fenders to clear..that may be a starting point..if you can find a rod friendly tire store so you can mount some various sizes for trial fit it would be a good thing.
Sam
Old 12-19-2010, 04:34 PM
Thanks for the feedback. The reason that I ask this question is that, as I was led to believe, because of the independent suspension and the fenders you can only run a certain size tire/rim in the front. In other words, I suppose I need the overall tire/rim diameter. Not an easy question to answer without actually trying different sizes.
Old 12-19-2010, 07:27 PM
The size tire will be greatly affected by the offset of the rim. I ALWAYS use a 165/80 15R on the front and a 235/75 15R on the rear.
I use the same size on my 32 Ford roadster also.
The sizes I use fill up the fenders without being TOO large ( IMHO )
Another factor to think about is the larger and wider the tire ... the heavier it is. Heavy tires increase the unsprung weight and can hurt the ride. Getting a 32 to ride real nice is difficult to pull off. That's why I use aluminum center sections and a aluminum driveshaft ... along with a coil spring 4 bar rear suspension.
The photo shows a BLACK steel driveshaft. It is now a aluminum one.
Old 12-19-2010, 10:49 PM
327NUT's Avatar
I've got a TCI.... IFS chassis, 195/65/15 and 255/70/16. As noted prior, you will find all kind of sizes used.
Old 12-20-2010, 01:40 PM
slow4dr's Avatar
205 Front 255 Rear is a very popular combo regardless of wheel diameter
Hi, My hobby is Tires & Wheels hobbytires General Rodding Tech 27 12-01-2007 06:37 PM
Tires for 4" wheels dh79 General Rodding Tech 6 07-27-2005 07:37 PM
What size wheels and tires to put on my 85 Silverado? leastbay Hotrodding Basics 1 06-15-2004 02:11 AM
What size wheels and tires to put on my 85 Silverado? leastbay Hotrodding Basics 0 06-14-2004 05:54 AM
Beware Coddington Wheels! 37cabriolet General Rodding Tech 18 12-24-2003 09:24 PM
