Sizing the front coli spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2005, 01:55 PM
I have a 1939 Ford PU and I am running a351W with AOD tranny. I used a Mustang II front end conversion (Fatman). The ride on the truck seems like it is "draging" a bit. I think the problem is in the shocks and/or front coil springs. Is there a way to size the coil springs and shacks so I know it is the proper size to carry the load and still make a good driver? Any information would be helpful
Thanks
JNJo39
Old 12-03-2005, 04:02 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Thanks
JNJo39
explain "dragging"
Are your lower control arms level?
Old 12-04-2005, 09:30 AM
xntrik
Thanks for your reply.
I am not sure what exactly I mean by dragging. The truck fells like it is bottoming out and on a smooth road it does not feel like the front end is solid. When I accelerate it doesn't seem to lift like I would expect. As near as I can tell the bottom control arms are level. I probably haven't been too helpful here, but the front end just doesn't feel comfortable
Thanks again
JNJo39
Old 12-04-2005, 10:22 AM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
There are some coil spring rate calculators listed in the Hotrodders Knowledge Base that might be helpful to you as you troubleshoot this problem. Here's a direct link: Suspension - Brakes - Steering Technical Data.
Old 12-04-2005, 03:49 PM
Take a look at this.
http://www.rqriley.com/suspensn.htm
and this
http://www.smithees-racetech.com.au/...cefactors.html
Springs should be sized by the desired undamped sprung mass natural frequency. Pick your natural frequency based on how you want it to ride, plug in the sprung mass to find the wheel rate. Then use the links that Jon talked about to find the needed coil rate.
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 07:03 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
mustang front clip swap 2wld4u Body - Exterior 5 11-02-2003 09:07 PM
Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps Jon Suspension - Brakes - Steering 0 10-12-2003 03:56 PM
staight axle interchange 27trackt Suspension - Brakes - Steering 3 09-02-2003 10:12 PM
