SK ratchet 45170 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2005, 06:57 PM
Mr.NutCase's Avatar
SK ratchet 45170
I have a SK ratchet 45170, What should i use to lubricate the gears in side the ratchet? oil? grease?
Is it easy to open the ratchet, what tools would i need to open?
Old 10-02-2005, 02:16 AM
aka Duke of URL
-SK TOOLS CATALOG-
The lube is available from either a tool truck or online. The illustration will show you the circlip that is held to retain the ratchet pieces in the handle. All you need is a set of needle nose pliers to take it apart.
Proto Ratchet Mr.NutCase Garage - Tools 2 09-23-2005 04:37 PM
air ratchet helrazr3 Garage - Tools 6 09-23-2004 11:14 PM
whats the deal with ratchet shifts the_new_kid88 Transmission - Rearend 7 08-01-2004 09:27 AM
street rod type of ratchet shifter? jon_volk Transmission - Rearend 4 12-29-2003 06:52 PM
ratchet shifters camino_man Transmission - Rearend 11 04-11-2003 07:17 PM
