SK6 truck kit check ball questions (C6) - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2011, 10:20 PM
I'm installing the SK6 into my C6. There's a spring under the check ball (converter relief?) closest to the pressure boost valve. The picture shows you swap a spring (I did) but it shows the little seat that the check ball sits on but no check ball.. Am I suppose to use the check ball with this spring or not?
Greg
Old 12-27-2011, 10:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Greg
C6 converter relief valve was a flat shape with a stem on it that inserted into the spring. This is located along side the main boost and PR valve
Old 12-27-2011, 10:52 PM
Its flatish, its dished for the ball. The pic shows no ball, do I put one back in? There was one originally..
Greg
Old 12-27-2011, 11:05 PM
It is the converter relief spring and ball (plus the little perch).
With the new spring does it use the ball? Or is it just the little perch?
I'm not getting a response by e-mail from the company I purchased it from...
Greg
Old 12-28-2011, 06:18 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Greg
No check ball is added there. The OEM converter relief valve has a stem into the spring. The dish area at the flat end is not for a check ball.
If there was a check ball there held by this relief check valve somebody put one there by mistake or thought they were helping.
The 2nd spring that holds a check ball in this C6 valve body is correct. TransGo often includes a special check ball with point on one end that replaces the round check ball
Old 12-28-2011, 03:05 PM
That's what I was wondering.. Thank you very much.
So I shoulda had just two check balls and not three (mine's a 79)....
4R100 check ball question bbuss Transmission - Rearend 0 04-21-2011 04:45 PM
turbo 400 check ball trouble antiquehorse1 Transmission - Rearend 9 09-01-2008 08:18 AM
Input shaft check ball 8843astro Transmission - Rearend 3 03-19-2007 04:29 PM
4L60E check ball location? gemini86 Transmission - Rearend 11 04-18-2006 10:02 PM
57 Hydra-matic check ball MeligN Transmission - Rearend 3 04-15-2004 07:29 AM
