sk700 junior kit for 700r4 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2012, 02:20 PM
Looking for opinions on the 700 junior. It it designed to make a tranny shift alittle firmer or is it designed to make them baby butt smooth or to just correct problems with pressures with relation to throttle valve etc. Just wondering what luck others have had with them. I installed one in my tranny and so far, not to impressed. Any thoughts out there?
Old 01-23-2012, 08:38 PM
Crosley's Avatar
Wiki Edits: 1659
The kit is designed for minor shift firmness improvements.. If a person has some operational knowledge of the trans and kit, easy to modify for firmer shifts as desired. ALso related to size of boost valves, servos and other mods.
junior stocker farm truck Hotrodders' Lounge 1 01-13-2011 08:08 PM
World Junior Hockey Custom10 Off-Topic 4 01-07-2011 07:00 PM
this is about the bad sh!@ junior stocker has put up about me buggmann Hotrodders' Lounge 3 09-29-2009 05:32 AM
junior cnorris30@gmail.com Introduce Yourself 1 04-09-2009 05:13 AM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
