Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Skip Wite Performance 383 or ZZ383 crate motor???
  #33 (permalink)
Old 12-29-2009, 02:39 PM
SKIP WHITE SKIP WHITE is offline
Originally Posted by ap72
block description says you have them bored to 4.125", standard 400 bore size. Then you run 4.030" pistons in them... Is piston slap a problem?
Yes we are running the 4.030 pistons in the 4.125 block, and did assume a little piston slap, and rattle, but one thing for sure is, them pistons go in the block so easy. We can't seem to get the engine to start.
Na, it's a type O as you must know. We offer this block in several bore sizes, and used the same add, but didn't get the specs matching throughout the add.
