Skip Wite Performance 383 or ZZ383 crate motor??? - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 01-22-2010, 06:57 PM
wow man it sure sounds like you all was coming down hard on his items. I'm from MD and no tons of people from DC MD and VA bought parts from skip white and are using the procomp heads I have - 2 sets 58cc 210 runners I have a little 327/30 over small block with his heads make 518 hp. I had Super Car Automotive check out the heads in May of last year they needed no work what so ever they told me bolt on go and bring the car to them after I put the motor together and dyno it, at 6200 rpm motor pulled 518 hp it was still claiming, will rev to 7400 rpm easy with hyd schneider cam grind. We all said WOW... They parts install from Skip White - Procomp heads 58cc 210 runners,
roller rocker arms 1.6 - 7"1/6 studs and girdle, Billet Distributor, Mini starter,
valve covers and gasket, exhaust gaskets, 3 pulley set, high flow water pump,a set of 8 I beam rods, fuel pump regulater, I only learn about the parts
at Budds Creek Race Way and at Cecil County Dragway in MD people are racing procomp parts and turning good numbers. I check the net and so many
forums read up on the there parts and for the many save and what I read and was told buy people who racing the procomp stuff I went that way to.
So to me make them very good heads
I have set Airflow reasearch heads right now 210 runners 2.08 / 1.65 valves
[IMG][/IMG]
Last edited by 68NovaSS; 01-22-2010 at 08:36 PM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
  #62 (permalink)
Old 08-20-2012, 09:47 PM
Originally Posted by SKIP WHITE View Post
I'm surprised at the opinion some of you guys have for the offshore products on the market, and it's understandable. The Procomp heads are just as they should be, as we have sold no less than 1500 pair worldwide. It is the low quality parts that many sellers install in the heads, and worse yet, the mismatch of parts, installed by someone that knows very little about how to do it. Shame on Procomp for letting their sellers do this Our problems with these heads have been few and far between, and it's the above mentioned that causes most all of the problems. As for the Pc rods we have also sold at least 800 sets with zero issues, and built at least 200 engines with them. You would be surprised at just who makes those rods. We know where to draw the line when it comes to offshore products. I have rejected many products due to quality issues. You don't see us using the low cost Procomp cranks, lifters and oil pumps do you. My value to the hot rod community is to offer products that have a very low failure rate, and that's exactlty what I do. As for the crate motor comparison in this post, you really don't realize what we are offering. Do you really think I would put together an engine using a brand new 1pc. rms Bowtie block with inferior parts. Low cost with little sacrifice, and no failures tolorated is our objective. For those not in the know, Scat, Eagle and Comp Star cranks and rods are all made in China. Scat has exceptional quality control, as I personally know the the owner of the company and he spends four months of the year in China.
There are many sellers on the market that will sell inferior offshore products, and could care less what happens to your engine if they fail. We do care for every good reason, and don't sell junk. I'm not here to push products, just trying to set the record straight.
I had the Pro-Comp Skip white heads with zero problems and as a matter of fact I am about to order 2 more sets, One
for the small block 79 Z/28 project and the other set for the 454 BBC trike project. Also for the record I went through 5 starters none of which really ever worked well on my project truck (Gearhead of the week 65 on powerblock TV) Last week I installed a Skip White mini-starter with the supplied stud bolts and for the first time ever the starter works flawlessly. This guy knows what works and sells only that!!!
383 crate motor backyard71nova Engine 25 12-30-2006 01:57 PM
260 HP or 290 HP GM Crate motor Iceberg Engine 4 02-26-2005 02:26 PM
Cam choice for new GM 260hp crate motor Iceberg Engine 3 02-22-2005 12:03 AM
To Crate Motor or not to Crate Motor wickster Engine 2 09-15-2004 11:49 AM
350 sbc crate motor questions bentwings Engine 7 10-29-2002 09:03 PM
