skippingt monte 86 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2005, 11:26 AM
skippingt monte 86
I have a 1986 ss monte carlo . Is there anyway to do with out the computer i have picked up a skip in the motor and can't get it out ..When i go to get the code it blinks 1-2 whitch means no rpm's .then thething starts to blink like crazy .. I can start the car and again it skips and blinks like crazy... can you help me in anyway ..
Old 07-21-2005, 11:45 AM
i dont know if you know so dont let me offend you. 1 blink followed by 2 blinks means the #12 code. this will blink 3 times in a series of * ** * **
* ** then it will give you the trouble code, example ** **** = 24 this will blink three times and then the next,( *** ** = 32 example) if you get * ** (12) six times in a row then it did not find a code and the problem may not be noticable to the computer. if it has only been a few hundred miles then give the computer a chance to code.
Old 07-21-2005, 02:13 PM
kstagger's Avatar
computer controls the carb, the distributor timing, and the transmission lockup...
if you want to go without the computer, check this page:
http://www.montecarloss.com/ubb/ulti...;f=17;t=008231
running w/o the computer will make the car emissions illegal...
I would do your normal tune-up procedures (wires, plugs, cap) and see if that helps with your miss.
c'mon over to the Montecarloss.com site if you have any further questions - good bunch of people over there.
Kevin
86 Monte Carlo erimar77 Hotrodding Basics 7 02-01-2005 09:57 PM
Bring Back the RWD V8 Monte Carlo!! Fragzem Hotrodders' Lounge 18 10-16-2004 11:35 PM
9 inch ford under a 86 Monte carlo HELP ME! ss crazy Transmission - Rearend 11 01-23-2003 05:35 PM
axles for 86 monte carlo Jooooooe Transmission - Rearend 6 01-06-2002 07:21 AM
86 monte ss converter and carb question raybear Transmission - Rearend 1 10-31-2001 03:27 AM
