Skylark TH-400 kick down switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2008, 01:14 PM
msc66's Avatar
Last journal entry: pics
I have a '66 Skylark that I put a 455 and TH-400 into. I'd like to hook up the kick down on the trans but 66s didn't come with the 400 so it doesn't have the wiring for the electric kick down.
I've been told I can just mount a micro switch on the gas peddle but I don't know how to wire it. Is it just a 12 volt source to the switch and then a wire from the switch to the kick down solenoid on the trans?
Thanks in advance.
Mike
Old 09-15-2008, 01:52 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You have it correct,
12v to one side of switch then to trans.
Rich
Old 09-15-2008, 02:52 PM
msc66's Avatar
Thanks Rich!
Old 09-15-2008, 06:54 PM
Originally Posted by msc66
Thanks Rich!
Actually, the Super Turbine 300 trans that came stock in your Buick (it is NOT a Powerglide) also uses an electric kickdown. The switch should already be in place. This same switch will also operate the kickdown on the TH400.
Old 09-15-2008, 08:07 PM
msc66's Avatar
Yeah, the original motor and trans is long gone and the wiring was a hacked up mess so any provisions for a factory kickdown are no longer.
I do remember a switch on the intake that was not hooked up and there were no wires. I thought it was for the switch pitch convertor. The ST300 did use one didn't it?
Old 09-16-2008, 11:29 AM
Yes, the ST300 used both an electric solenoid kickdown and another electric solenoid valve for the switch pitch. The switch on the intake would have had terminals for both. B&M and others sell generic switches that go on the throttle linkage as noted above.
Old 10-07-2008, 09:29 PM
kick down
I have one for sale right now on ebay
http://********************MT:31
Last edited by poncho62; 10-08-2008 at 10:17 AM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Trinary Switch from Vintage Air ElegantInventor Electrical 29 06-15-2011 07:44 PM
wiper switch Big Dog Daddy 2008 Electrical 2 06-29-2008 07:02 AM
GM switch info(application) sha_ba_do_bang Electrical 5 10-23-2006 12:01 AM
Edelbrock Carb TH400 Kick down switch lazydawg Engine 2 08-10-2005 03:42 PM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 09:31 PM
