slammed 454 ss silverado widest tire in rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2014, 08:03 PM
ss454lemy's Avatar
hey guys im looking for a pro street type look with out having to cut up the truck. im looking to run some 315 out back with a 15x10 wheel. i like to see pictures of c1500s with nice setups and there info. i look but i can seem to find info on the back spacing for the wheels. i have 4-6 drop on my truck. thanks in advanced
Old 03-20-2014, 08:37 PM
johnnyg's Avatar
hold my beer and watch this!
Truck & SUV - Custom Truck News, Reviews, Videos - Truckin' Magazine
Old 03-20-2014, 08:43 PM
Last journal entry: New Rev wheels and BFG KDW II tires
Your best bet is to measure your truck yourself. It's really not that hard. That way you will know you are getting the biggest tires you can. It would be a huge bummer to rely on someone elses measurements and find they don't work for your truck.
https://www.youtube.com/watch?v=jkQFUH_dvnI
Old 03-20-2014, 08:45 PM
ss454lemy's Avatar
didn't see anything
Old 03-21-2014, 04:52 AM
astroracer's Avatar
I just got new tires and wheels for my '95 Sierra. American Racing aluminum Rallyes, 18 x 10's in back with 6.25" BS. The tires are 295/45's. 6" would have worked but I wanted room for "adjustment". I may end up making some 1/4" spacers for the back once I get the truck out this spring and have some driving time on the new set-up.
These fill the wheel well with about as much tire as you can stuff in there. The outer lips are trimmed.
I don't know how similar or different your fleet will be to my step so you should measure your truck to verify the numbers. I can walk you through it if you want.
Mark
Old 03-21-2014, 05:17 AM
ss454lemy's Avatar
I don't know how similar or different your fleet will be to my step so you should measure your truck to verify the numbers. I can walk you throught if you want.
Mark
that's a nice truck! i like your set up. i seen a couple people running a 325 on these fleet sides im happy with a 315!
Old 03-21-2014, 07:52 AM
ss454lemy's Avatar
im looking to get the centerline convo pros but i cant seem to find them in 6 bs i seen them 5.5 6.5 but no 6
Old 03-21-2014, 08:40 AM
ss454lemy's Avatar
this is more or less the look im looking for the forward looking truck this is what he has posted 30"x13.5 E/T street on a 15x10 wheel with 5" back spacing is about as big as I could get under the rear.
but i don't get approved for that web sight i don't know why...
Old 03-21-2014, 08:58 AM
ss454lemy's Avatar
this is the forward facing one i was talking about sorry
Old 03-21-2014, 10:25 AM
astroracer's Avatar
With your 6" drop you have no room for error. The tall tires you are looking at NEED to be tucked just right to prevent rubbing. You need to measure the room you have between the inner bed and the fender lip, that will dictate how wide you can go with the tire. The distance from the wheel mounting face to the inner bed wall will dictate Back Spacing.
I really doubt you will have room for 315 back there with the drop. I could have stuffed a 305 into mine but that was leaving only a 1/4" clearance all around and the trucks do move side/side on the springs during a hard corner so that was just to close...
Mark
Old 03-21-2014, 10:47 AM
ss454lemy's Avatar
Mark
i don't mind lifting back up 2 inch i have the stock shackles just in case. i know there's a way of swapping the leaf springs from one side to the other and putting them in the inside of the chassis. then ill be able to run 14 wide but i didn't want to get that big of a tire...
Old 03-22-2014, 09:51 AM
S10xGN's Avatar
Gotta love a turbo!
Although my S-10 is not dropped, I'm able to run Hoosier 325's on 10" wheels with 5.5" BS and the bump-stops removed. You should be in better shape than me...
Russ
The Following User Says Thank You to S10xGN For This Useful Post:
ss454lemy (03-22-2014)
Old 03-24-2014, 09:21 AM
ss454lemy's Avatar
i might move the leaf springs to the inside of the chassis and run a 12in rim with a bigger tire and some tubs. that way i don't buy wheels twice! well see, ill deal with the stock with a 275 dr for now.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
widest wheel/tire botch390 Transmission - Rearend 0 01-05-2012 04:49 PM
Widest Tire Size mightycarlo10 Suspension - Brakes - Steering 2 12-25-2007 07:01 PM
Widest tire under a 72 El Camino sb72elcamino350 General Rodding Tech 11 09-16-2004 12:47 AM
widest tire for my 65 chevelle freerider99 General Rodding Tech 4 09-11-2004 10:33 PM
Widest tire under a 72 El Camino sb72elcamino350 Transmission - Rearend 8 02-25-2004 06:20 PM
