slamming a 65. PICS! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2008, 04:57 PM
I picked this thing up for 1500 bucks off some kid locally. It was a peice of ****, no lie, tons of bondo, gallons to be more exact, rust, and so much other ****. Now after about 3 grand, its coming together.
truck is going to be slammed, on factory wheels, painted gold flake, and white walls, BUT, i notched it so if i got the money, i could tuck 24s.
painted satin black with gold flake scallops and cream pinstriping, Chopped 3 inches, shaved rain gutter, shaved mirriors, dash, emblems, tailgate. Custom made grill(photos once its done about 1/2 way finished now) and a built 352/c6.
how it looked when i bought it.
huge notch.
lower link bars. and cross member mock up
bag mounts/drive shaft tunnel.
just a neat photo welding overhead
more photos soon, im going to finish my triangulation link bars tomorrow. then ill have pics of the whole back half put together.
not to shabby for my first bag job/time ever using a tube bender.
Old 05-26-2008, 05:47 PM
31 five window
Last journal entry: Moving along with patch panels.
It looks very good but you better put some more strength on the bottom bar if you are going to bag it there.
Old 05-26-2008, 05:54 PM
yeah i know. The link bars arent finished yet. The steel yards where closed for the weekend. The supports for the lower link bars are going to be the same as the rest of the tube. .120 wall 1.5 OD DOM, But it will be bent near the axel and taper into the link bar.and im going to plasma cut something cool looking to fit in the gap that will be left there.
Old 05-31-2008, 08:24 PM
an update finally.
heres some photos for oyu guys.
the 4 link is finished, and everything is welded in. These pictures are from during the whole process so some are of things tacked in place in such, b ut you get the idea, and a few extras in there too.
the shop
notch welded in, just a close up to see craftsmanship. MIG welded.
bag brackets with upper link tabs welded on
finished 4 link
front triangulation tabs tacked in place
links again
gas tank
Old 05-31-2008, 08:28 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
You will have alot of weight pushing down on the middle of the bottom bars. Look's good other then that.
Old 05-31-2008, 11:44 PM
yes i know, they are going to have supports on the bottom, another peice of 1.5 inch OD .120 wall Bent with a 1/4 inch pplate gusset between the 2.
Old 06-01-2008, 10:05 AM
Old 06-01-2008, 10:44 AM
31 five window
Looking good,great welds.
Old 06-01-2008, 10:50 AM
thanks for the support guys. need to get some more people to look at this thread
74 to 65 rear end gear swap? 65_Chevy Transmission - Rearend 4 06-26-2005 01:29 AM
Looking for info on 65 Belvedere MsMopar Body - Exterior 3 05-02-2004 09:07 PM
Pics of the scoops on my truck. Rubberman2003 Hotrodders' Lounge 13 01-27-2004 07:39 PM
The Last of the Rat Fink Pics Pinto_Guy Hotrodders' Lounge 3 07-23-2003 04:42 PM
