yes you do need a ballast resistor to make that run. you should see 2 hole on the firewall where the old one was mounted. if you don't know what they look like.........it is a ceramic rectangle with a connection on each end.
I have no idea. I see blue ones, brown ones... lol
If it were me- I'd be looking very hard for a wiring diagram for your particular car. I notice some diagrams do not actually say "this is the ballast", but you should be able to look at the diagrams and figure it out. There will be a wire running to the ballast from the "+" side of the coil- usually brown- can't miss it! Enlarge the diagrams by holding the cursor over the diagram until the expand box appears in the right bottom corner, then click on it- else it will be next to impossible to read.
Mopar Slant Six (and other Mopars and AMCs) Ignition Modification
Hi HammerGVette, the need for different ballast resistors depends on if you have an electronic ignition system or not. I am active in 'slantsix.org', and what we actually recommend (mopar diehards read the links before making grufff) is a switch to GM/Ford ignition parts, used with a stock Mopar distributor. One of the reasons is to get rid of the ballast resistors, secondly to get a hotter spark, thirdly the new mopar parts you may need is mostly chinese made (s)crap! See this link, extremely much info there. The modification also applies to Mopar V8s, for V8s there is even a cool little custom billet bracket to mount a GM ignition module on the underside of the dizzy available on the web. AMC owners have the same issues with their ignition systems, this mod. is discussed on several Jeep forums. I am myself in the works of mounting a GM ignition module (Standard #LX301) and Ford coil (Standard #FD478) on my slantsix Aspen.
I hope the moderators here don't mind me directing people into another forum, there is no competition between us, and these are relevant issues to keep the SlantSixes running for another 40 years, but now with a lot more power and driveablility. (...there is an australian 679hp slantsix Valiant on youtube...) Besides, SlantSix hotrods are way cool! Olaf |
I drove a slant six for a while, and had a ballast resistor go out on the side of the road, so i ran a wire directly into the ignition coil from the battery and tried starting the motor. if you do that and it starts, it means all that you will need the ballast resistor. (to my understanding you can't run without one or it burns the coil up)
Get an aftermarket coil, they can run on 12VDC all the time negating the need for a ballast resistor. Might as well go completely electronic, you can even keep the points style ignition trigger if you want.
You need to get a wiring diagram or at least look at an intact car so you can figure out the wiring. Should be an example in a junkyard somewhere near you. Since most Dodges use the same color coded wiring this Challenger diagram should be similar.
Outlawed tunes from outlawed pipes |
Here's a 1971 Dart front wiring diagram, from the link in post #6. The original question was from a couple months ago, but perhaps it'll help someone doing a search for similar info:
Hi HammerGVette, because you haven't bought the parts yourself, and therefore cannot be sure of what you have, your coil may also be one of the aftermarket 'high performance' coils that use a non-standard size ballast resistor that is bypassed with full voltage from the starting circuit, and then is fed via the resistor for normal operation. As pointed out by another member, such coils cannot function for a very long time without a ballast resistor. If you have a points distributor, '4 Jaw Chuck' and 'cobalt327's diagrams show you all you need. If the previous owner installed an electronic ignition system, he may have used the diagrams in this link: Electronic Ignition Conversion Instructions.
For testing your coil: Mopar Coil Test Procedure Single ballast resistor electronic ignition systems: (4-Pin Electronic Ignition) Dual ballast resistor electronic ignition systems: (5-Pin Electronic Ignition) Mopar wiring diagrams from 1955 trough 1976, cars and some trucks: Mopar Wiring Diagrams Simplified Charging Diagram w/Dual Field Alternator & Electronic Voltage Regulator: Dual_Field_Alternator_Wiring (not correct if late model or aftermarket single wire alternator is installed) In my personal opinion, a high performance system like the MSD is overkill on the SlantSix, the HEI mod will give plenty performance for a lot less money. Olaf Last edited by olaf; 05-02-2010 at 01:36 PM. |
| HEI ignition Question? | Studebaker | Electrical | 1 | 12-01-2008 01:01 PM |
| Ignition Question | 1957chevyrod | Electrical | 0 | 10-03-2008 10:12 AM |
| MSD ignition question?? | HemmiGremmie | Engine | 2 | 01-05-2006 08:25 AM |
| 1969 Camaro HEI ignition location Question | Izzy17ri | Engine | 1 | 12-08-2005 04:38 PM |
| Rertronix Ignition Question | Dave E Shank | Engine | 30 | 12-30-2004 05:41 AM |
