slant six 225 cam choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2009, 12:33 AM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
I am rebuilding my aunts slant six. shes a teacher not a hot rodder lol.
I need help figuring out what cam to get. i want a smooth idler. it has low compression (around 8:1 i believe maybe 7.5:1) i need new springs valves and push rods and lifters.
it is a solid lifter right now. .406 intake .414 exhaust
will a 252 idle smooth in the 225?
Old 06-17-2009, 02:45 AM
327NUT's Avatar
Why not just put a stock cam back in it??????????
Old 06-17-2009, 05:43 PM
i cant find the stock size cam.
it needs a new cam becuse the one that is in there now is very very worn down.
Old 06-17-2009, 06:01 PM
Wiki Edits: 31
Napa will have the correct cam
Old 06-18-2009, 12:08 AM
never thought of going there ill call them tomorrow. thank you.
Old 06-18-2009, 07:10 AM
yes, a 252 cam (advertised duration) will have a smooth idle.
Old 06-18-2009, 02:10 PM
ok cool. this is my first slant 6 rebuild and cams still confuse a little bit. so as long as the 252 idles smooth in the slant six im happy i dont want to give my aunt a car that sounds like its doing 50 and a stop light lol
Old 06-18-2009, 02:12 PM
Banned
If you clean up the casting and watch your clearances you may give her an engine taht runs better than it did from the factory. I bet that would be a pleasant suprise for her.
Old 06-18-2009, 03:19 PM
I really want to clean up this engine for her. i want to clean up this engine inside and out as much as i can plus paint it for her.
Im upgrading the entire valve train so it will perform much better then it did.
should i know anything about the slant six???
tricks for more gas mileage or performance???
and since the cam is a bit bigger should i increase the timing a few degrees??? the book says (factory parts) at TDC. so maybe 4 more degrees??? i guess i wont really know till i fire the engine.
Old 06-18-2009, 03:39 PM
Banned
If you want to mess with timing keep total the same but maybe a few more degrees initial.
283 cam choice JohnyR17 Engine 4 01-08-2008 06:30 AM
smart cam choice? opinions valued. classic keith Engine 21 04-10-2005 08:26 AM
Cam choice,, Please help!! Lthompson Engine 23 02-09-2005 06:05 PM
383 cam choice markn Engine 10 07-02-2004 01:29 PM
225 slant 6 ricekiller Engine 5 01-16-2003 03:26 PM
