Slave Cylinder Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2006, 05:13 PM
Slave Cylinder Leak
The slave cylinder on my Mustang is leaking REALLY bad. You should see the PS fluid on my garage floor. It always dripped a little but lately it's to the point of repair or replace. I bought a seal kit for it, but I would like to see a blowup of the cylinder before I start. If anyone out there has one or knows a site to find it, that would be great. Better yet, a step by step process of replacing the seals. Thanks.
Old 09-29-2006, 10:22 PM
sedan delivery's Avatar
slave cylinder
what year mustang---i hope your are using brake fluid unless the system requires ps fluid. post the year
Old 09-30-2006, 11:00 AM
The Mustang is a '65. They use Type F fluid. Any help on finding a blowup for the cylinder?
Old 09-30-2006, 05:39 PM
slave cylinder
cant find the imformation you need at home-- i have a system at work called aldata that we use in our repair shop. wont be able to check on it till monday
Old 10-02-2006, 05:28 PM
slave cylinder
i did find the fluid specs on the hyd. clutch system. use either dot3 or dot4
brake fluid. not ps fluid or trans fluid. these oils will attack the rubber cups in the system and cause a leak. if you can find kits to overhaul the clutch cylinder and slave cylinder. these parts will have to be cleaned , use alcohol
to clean. there should no sign of oil in the system before rebuilding. if you can dissemble the parts just lay the parts out as you take them apart.you will see what the oil has done to the rubber parts.--good luck
Old 10-03-2006, 03:59 PM
slave cylinder
to start out- mustangs from 1964 to 1972, had mechanical clutch linkage. the slave cylinder did not come in till 1973 with the mustang ll. so you can do what you want with this information. i think you dont know what year it is.
Old 10-05-2006, 07:25 PM
abstruse dutch uncle
He's probably talking about the power steering actuating cylinder on the steering linkage.
I don't have a diagram. You need a service manual.
If you can figure out how to take it apart, the new seal positions should be fairly obvious. It's just a piston in a cylinder with some seals.
hd 3500 slave cylinder removal propaniac Transmission - Rearend 2 09-26-2006 02:40 PM
clutch hydraulic slave cylinder automan431 Transmission - Rearend 2 12-31-2005 10:25 PM
master cylinder vacum leak 65Guera Suspension - Brakes - Steering 4 09-14-2004 12:21 PM
slave cylinder Super Chevy Transmission - Rearend 6 01-04-2004 09:43 PM
clutch slave cylinder mount wally Transmission - Rearend 1 03-04-2002 09:20 AM
