sleeving a 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2006, 06:49 PM
dboyett38666's Avatar
sleeving a 400
Is it worth it to sleeve a 400 small block that is 40 over I was going to have it bored 60,but the guy at the machine shop said the bottom of the cylinder has moved.Would I lose alot of power just building a 383 stroker.I am trying to get the car in the 11s,should I sleeve the 400 hundred or use a 350.How much does it cost to have on sleeved? Any info would help
Old 03-03-2006, 08:37 PM
Well, if you got a combo that is capable of 1 HP per cubic inch, you talking about 24 horsepower difference between the two. I personally wouldn't be a bit afraid of a properly sleeved block, in fact I've got one. I also like the additional unshrouding that the larger bore provides. But Im partial to 400's also.
Old 03-03-2006, 09:15 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I like the 400 as well. You can sleeve it back to stock 400 bore with no issues.
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
400 cid SBC Shades_o_Grey Engine 20 02-04-2008 12:28 PM
400 Combinations MI2600 Engine 15 05-12-2006 07:08 PM
400 327 crank limey Engine 8 09-24-2002 07:53 AM
Small Block 400 chevyelc81 Engine 9 06-18-2002 06:10 PM
