Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sleeving this block
Old 03-08-2013, 06:47 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
I sleeve blocks with that type damage. Nohing out of the ordinary.
As previously stated. Cost can be a major factor. Block will usually have to be completely over bored because of press fit distortion of adjacent cylinders. Cleaning, Cam bearings/s plugs removed for complete machining chip removal . Figure= Labor
Remove cam bearings/soft plugs, clean block.
Crack inspection
Sleeve install
Bore/hone block.
Install cam bear/soft plugs.
Parts=
Sleeve
Pistons/rings
cam bearings/soft plugs.
