Sleeving SBC cylinders? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2010, 09:05 AM
v8hed's Avatar
AK427
The Vortec block I'm currently building has 2 damaged cylinders (scored walls due to shrapnell when the engine let go in its previous application). All the other cylinders are perfect with cross-hatch still just about visible. Although I anticipate the scored cylinders will probably clean-up at 40 over, my machinist (who doesn't know anything specific about SBCs) suggested I might want to consider sleeving the 2 damaged cylinders in order to retain the original bore size and avoid unnecessary work on the other 6 cylinders.
Is it possible to sleeve an SBC in this way?
Thanks.
Old 03-05-2010, 09:15 AM
ericnova72's Avatar
More for Less Racer
Yes, but the interference fit required for the sleeves will distort the cylinders next to the ones you sleeve when the sleeve is pressed in, requiring them to be bored oversize to get them back round again. Sleeving not the best option when the only problem is scored walls and a common oversize is available, sleeving best reserved for more extensive damage like a split cylinder wall.
Old 03-05-2010, 09:56 AM
v8hed's Avatar
AK427
Thanks for info... I'll stick with a rebore to +30/+40.
Old 03-05-2010, 09:57 AM
bentwings's Avatar
bentwings
I'd just bore the bad holes oversize and cleanup the others if at all possible. It's no big deal to have a couple .040 holes and the rest std. Be sure you mark the holes for future reference. If you really want to split hairs you can match the weight of the .040 pistons to the std pistons. I reserve sleeves for the really bad stuff, deeply scored or split walls. I've run motors with 8 sleeves and even removed and re-sleeved as necessary. It's always risky when you have to bore into water. By this stage of the game it is done to save an expensive block or hard to replace block. Maybe get a few more miles or few more runs out of it while you are looking for a new one. I don't get carried away with re-plate honing a sleeved block as the block will go everywhere but straight anyway. I've seen 8 sleeve blocks leak only 2% for a long time and other times a single sleeve won't seal at all. It's gamble anyway you do it. The real exception is diesel blocks. These are regularly heavily sleeved and often re-bored again. The saving factor is there is a huge amount of iron in a diesel block and they are very rigid in any case.
If your guy doesn't know what he is doing, find someone who does. It's not extreme science. Standard engine practice.
How many cylinders do you have? Chris Kemp Hotrodders' Lounge 47 05-26-2009 08:21 PM
oil drain on SBC heads TerroRx7 Engine 7 03-17-2005 03:12 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 11:12 PM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 10:02 PM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 04:44 PM
