Slick Craft ss 245 with OMC 235 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 03:13 PM
That's what I have. Engine 351 WCP 4. WHAT means . I want to buy refurbished one. How and what I need to buy...engine I said!!! TKS
Old 08-24-2008, 04:11 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You can Google to find the boat parts you need.
Old 08-26-2008, 03:08 PM
it is language barrier??? i said what type of engine is according with the CODE that I give?
Old 08-26-2008, 04:03 PM
onebadmerc's Avatar
I need a bucket of arc sparks
That sounds like a boat engine OMC (Outboard Marine Corporation) which doesn't exist anymore. Polaris bought out what was left of OMC about 10 years ago. Probably a 235 HP Ford 351W, and the slick craft is the boat make but that is just a guess.
Old 08-26-2008, 04:59 PM
woodz428's Avatar
Troll Hunter
Am guessing Troll...No??? Possibly language barrier?? Code sounds like casting on block instead of code...but maybe language barrier.
Old 08-26-2008, 05:12 PM
Wiki Edits: 31
boat engines in the 70's were titled by there HP ratings.. OMC 235 was a 235 HP 351W.. the 4 part probably means 4bbl carb...
Old 08-26-2008, 08:33 PM
woodz428's Avatar
Troll Hunter
That 351 WCP 4 is also cast into many lifter areas too. Windsor Casting Plant...that's why my comment on troll. I think the 4 is there as well. I'll have to look in the shop tomrrow, but pretty certain those #s came right from the block casting.
