Slick Sand - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2007, 07:48 PM
SHIFTY101EASY's Avatar
Last journal entry: Stripping Paint + Buying New Metal
Slick Sand
okay so if i were to want to use a single stage urethane paint do i epoxy primer over bare metal and filler first or do i use something like slick sand to spray down first, block that out and then just use the epoxy primer as a final sealer before the color coat?
Old 02-07-2007, 08:04 PM
epoxy first
bondo second
slick sand third
epoxy fourth
color fifth
smile sixth
Old 02-07-2007, 08:18 PM
do i do the entire car in slick sand or just the flat panels...?
Old 02-07-2007, 08:41 PM
slick sand is only for extreme high filling. if you dont need that much then use a 2k primer. i only use slick sand on wavy panels or panels with alot of dents and dings in them. slick sand is basically liquid bondo.
Old 02-07-2007, 08:43 PM
okay so i should prob get like a quart or so then just to have, correct?
Old 02-07-2007, 08:46 PM
yes. how are the body panels now??
Old 02-07-2007, 08:55 PM
umm all good except the driver side quarter panel (new door, fender, hood, trunk lid...only original panels are the quarters and passenger door....soo i dont think its gonna be a big deal getting the new stuff smoothed.....i popped out the dents i could get to and did a bit of kitty hair to fill the real low spots...sanded that down with a DA then skimmed it with some regular z-grip filler.....i bought some glaze coat stuff too which will prob be more useful after the epoxy is down.....
Old 02-07-2007, 09:00 PM
i would get a quart or two just incase. remember to block your panels using guide coats to check for high/low spots.
Slick Sand problem oldred Body - Exterior 2 09-20-2006 12:07 PM
Newbe with queston about slick sand primmer chevellenut Body - Exterior 3 07-22-2006 10:15 PM
Evercoat Slick Sand, Featherfill, G2, Polyester Primer Surfacer scrot Body - Exterior 6 05-27-2006 03:27 PM
Slick Sand - Blocking evill Body - Exterior 30 02-16-2006 02:36 PM
Seal slick sand? oldred Body - Exterior 4 08-02-2005 08:33 PM
