I use slick sand all the time great stuff. Once you mix it you have about 45 minutes before it hardens. I spray 2 coats and block out the next day. When you block sand it turns light gray and you can see the low spots or scatches as they are alot darker. I use SPI black epoxy first so it is easy to see high spots.
