Slide hammer dent pullers - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-08-2010, 02:05 PM
Here is a little video of the stud welder in action, both pulling and shrinking.
If you will notice I just TAP the trigger, holding it there burning the stud into the metal. You will notice the stud comes right off the metal after pulling. An even lighter tap will do the job. Being under pressure of the camera I didn't do it as I usually do, even faster tap on the trigger. On many dents the stud doesn't need to be anywhere near that well welded on. I will usually put it on so light I have to very carefully slide the slide hammer on being careful not to push it to the side AT ALL or it will simply fall right off.
http://s200.photobucket.com/albums/a...t=100_0547.mp4
Here is the shrinking tip. It will work, but I don't like it, does more damage than good.
http://s200.photobucket.com/albums/a...t=100_0548.mp4
  #17 (permalink)
Old 11-08-2010, 02:39 PM
Here is the shrinking tip compared to the stud tip.
  #18 (permalink)
Old 11-08-2010, 03:32 PM
Here is the slide hammer I use. I really like it, it comes off the stud very easy.
ID:	49805   Click image for larger version
  #19 (permalink)
Old 11-08-2010, 06:20 PM
Wiki Edits: 27
Working out dings
I watched metal finishers in the factory use a lot of different shaped J or L tools. A T handle welded to the end of a hood or deck lid torsion spring and various lengths. Work the tool in through an access hole or punch a hole in a hiden area and pry then work like a finish picking hammer, then a daub of sealer over the hole. They used those more than the weld studs.
  #20 (permalink)
Old 11-08-2010, 07:02 PM
FRANKBULLITT's Avatar
On alot of dents we use the glue on dent pin to pull out works great and no hole !
  #21 (permalink)
Old 11-08-2010, 07:55 PM
In the seventies I was guilty of drilling, screwing and snatching with the dent pullers but then I evolved! I now use my old slide hammer dent pullers for seal pullers.
Slide Hammer - Which one? AustinPhoenix Body - Exterior 2 02-12-2009 12:59 PM
Needed a slide hammer pepi Garage - Tools 4 10-27-2007 10:25 AM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Hammer and Dolly tool review MARTINSR Body - Exterior 12 10-20-2005 05:33 AM
my doors got stretched nomad57ry Body - Exterior 17 12-02-2004 06:51 AM
