Slide hammer dent pullers - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2010, 10:15 AM
Are the drill a hole ,put in a screw dent pullers necessarily a bad way to pull dents? Assuming that the hole will be welded shut afterward?
Old 11-06-2010, 11:25 AM
poncho62's Avatar
Wiki Edits: 5
These days, slide hammers are used with welded on studs that the puller attaches to.....then, the studs are ground off.....no holes
Old 11-06-2010, 11:39 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
about the most worthless tool ever made. like a screw is really going to hold . this is what some moron did to my truck. to stupid to reach around the corner and bump it out.
Name:	cab corner.jpg
Old 11-06-2010, 11:57 AM
LOL he got screw happy
Old 11-06-2010, 11:59 AM
LOL. Take him to Nancy Grace new court show... He basically destroyed it. Seems like after the first hole he would've said, "This Ain't Gonna Work".
Old 11-06-2010, 01:30 PM
As everyone has said, that screw slide hammer was the WORSE hack tool ever made. And back years ago, sadly it was "the tool", I used it plenty! When I think of how I used one I want to climb under a rock, that a piece of crap that tool is!
I used an awl to punch it, not drill the hole which turns into a little "volcano" when pulled, punching the hole at least didn't do that!
What is really sad is how many holes got drilled in metal when there was access behind the dent to push it out if they had simply removed a piece of interior trim!
Here is how it is done today, which can STILL be hack if used incorrectly of course.
You weld a stud to the surface of the metal.
Here is a pretty neat little overview on the use of the tool.
http://www.bodyshopzone.com/archives...ud_welder.html
Old 11-06-2010, 02:15 PM
i too am guilty of drilling and jerking many years ago,we got a stud gun 15 or so years ago and never looked back,well except when things catch fire
drilling and jerking doesn't sound good,lol!!!!!!!
Old 11-06-2010, 04:37 PM
milo's Avatar
point on positive
If you have a mig welder sometimes you can tack a nail or a pull tab and pull with a pair of vise grips...While they are hot hold rag soaked in cold water to help put some shrink in there as you go..
One dent one car one time yeah a hole with a sheet metal screw and a pair of vise grips is a way..
depends on how many dents your gonna work to justify the cost of a stud welder,,if you have more bodywork in your future
then stud welders can do some magical things..
dents in side of surburan
Old 11-07-2010, 07:50 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
They used to say that the holes gave the Bondo more grip.
Old 11-07-2010, 08:53 AM
LOLOL, I remember that! Yep, and we believed it!
Old 11-07-2010, 05:37 PM
scrot's Avatar
...and the Bondo worm was invented.
Old 11-07-2010, 09:10 PM
mitmaks's Avatar
Last journal entry: Grille
that's what happened to my Charger years ago when some idiot owned it before me
Old 11-08-2010, 09:45 AM
66SSImp454's Avatar
Justin
Question on the stud welder. Is there any concern of overheating the metal and warping it?
Old 11-08-2010, 10:22 AM
The metal is already pretty bent up, so a little "warp" isn't going to matter much. But honestly, I don't believe in "burning" the stud in like a lot of guys. I was taught by someone to BARELY tap the button so that the stud is barely held on. Once you do your pull the stud should be able to be simply pushed sideways and fall on the floor. Using it that way, you are applying VERY little heat. I have literally metal finished small dings after pulling them out with the stud welder.
There is a shrinking tip for the stud welder. I have one, don't like it a bit. The spring in the head is so strong that when you push on the metal and hit the button the heated metal stretches with the tip pushing in a big dent! But it does "shrink" if you heat it up and cool with air or water.
Old 11-08-2010, 01:43 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
A pair of Vise-grips welded to the fitting on the end of a
regular slide hammer works much better than the pullers that
comes with most stud guns.
You don't have to push it to release it, and can go back and forth
over your studs much quicker.
Slide Hammer - Which one? AustinPhoenix Body - Exterior 2 02-12-2009 12:59 PM
Needed a slide hammer pepi Garage - Tools 4 10-27-2007 10:25 AM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Hammer and Dolly tool review MARTINSR Body - Exterior 12 10-20-2005 05:33 AM
my doors got stretched nomad57ry Body - Exterior 17 12-02-2004 06:51 AM
