slight bind on consew - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2009, 12:29 AM
My 226 has developed a slight bind. I can feel it turning the handwheel forward. when turning backwards no bind. Occasional broken top thread. Any ideas
Old 09-13-2009, 09:14 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Change the needle and see what happens. Sometimes it will get slightly bent and hit the opening on the foot.
Old 09-15-2009, 12:10 AM
I installed aa new needle and oiled the machine and seems the problem is gone. I have one question. Is the oil well below bobbin supposed to remain full of oil? Could not find any guidance in the manual
Old 09-15-2009, 07:14 AM
Wiki Edits: 22
The Consew 226 is not self oiling, so there really is no oil well below the bobbin. Just put a couple drops of oil next to the bobbin, and it will end up where it needs to go.
4l60e 4th bind, burns the band. Twistedwrench Transmission - Rearend 1 03-10-2009 10:26 PM
700r4 slight bind on 2-3 tnsmith10 Transmission - Rearend 4 11-16-2008 04:18 PM
Got the base down, slight orange peel, what to do before clear? shad9876 Body - Exterior 6 08-14-2008 04:49 PM
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
slight clunk/ shift kit install Q's HARVICKx29 Transmission - Rearend 2 02-16-2004 09:51 PM
