slight hesitation at take off - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2010, 11:19 PM
I have a slight hesitation at take off and i am not sure what it could be? Could it have to do with the squirter or the the accelrator pump spring giving to much fuel or not enough?
Old 04-30-2010, 01:15 AM
ericnova72's Avatar
More for Less Racer
This is usually the squirter being too small, not enough fuel being added, as long as the timing is right for your application. Make sure there is no free clearance at idle on the pump arm to lever, but make sure there is also still some spring left to compress with the throttle held wide open, you don't want to bind the linkage at wide open throttle.
Make sure the accelerator pump squirts instantly with even the slightest throttle movement, any lag is bad.
hesitation 1966 CHEVELLE Engine 1 04-07-2010 05:01 PM
Slight Hesitation in Small Block Chevy jvgrago Engine 14 05-03-2008 11:04 PM
4.3L Hesitation Problem... drluv Engine 5 07-11-2007 06:42 PM
Hesitation! frankenvette Engine 17 05-18-2006 04:55 PM
Hesitation 1969NovaSS Engine 5 08-01-2005 09:11 AM
