slight humming noise at idle and knocking? noise on slow acceleration - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2011, 08:49 PM
Alright back once again, i hope it's nothing serious this time, maybe it's just me being paranoid. But i just put this engine together. I've been told by some people that this may be noises from the roller rockers and or the camshaft(it's something like 500 lift, if that matters)? doesn't make sense to me, but i've been searching and can't find anything, and don't want to do any tearing down as it's a very very light noise, and is hopefully just me being paranoid. Anyway on to the problem. At idle occasionally you can hear a very light humming or whooping noise, this sound really doesn't worry me because it's so light i can't even dial in where it's coming from yet. The one that really worries me is on light acceleration, somewhere between 1k-2k rpm you can hear a very light knocking noise from the engine bay, or maybe tranny, i can't really say for sure. Since i can't get it to make the noise sitting still i can't really dial it in. It's so light you have to have the windows up and everything quiet and really be paying attention to hear it. So any ideas on what this might be folks? someone just tell me i'm being paranoid please!! thanks as always
Old 05-11-2011, 09:38 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
You might try an auto style stethoscope. If you have to go through all those changes to hear something, then I doubt it's anything but normal noises, heck I'd bet I wouldn't even be able to hear it.
Rich
Old 05-11-2011, 10:01 PM
cjoform's Avatar
I would highly doubt anything internal such as a rod knock. You would be able to reproduce that sound at idle. You may look into the flexplate and torque converter. Make sure they are tight.
Old 05-12-2011, 03:53 AM
sqzbox's Avatar
My pipes are my music
I had a problem like that once. Turned out to be a bunch of junk in the fan housing in the heater blower that constantly runs unless the knob is turned to the off position.
Old 05-12-2011, 05:54 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
I had a very light humming / fast soft buzzing sound at low idle and found it to be the PCV valve in the passenger side valve cover.
Could your knocking be the beginning of detonation?
Old 05-12-2011, 06:14 AM
i've been trying to find it with my stethiscope and can't really hear anything at idle. I was wondering about the flexplate, and torque convertor as well. i checked the torque convertor bolts and they are tight. the flywheel was torqued to 80 ft lbs with red locktite so i seriously doubt it is coming loose. Not using a pcv at this time. i wouldn't think it would be detonation, as i can lug the engine down and floor it and still not hear any pinging noise. and it's definetly not coming from the blower motor area.
Old 05-12-2011, 08:47 AM
sqzbox's Avatar
What kind of fan are you running for the cooling system? Also, might want to start looking at the accessories, pulley's, and belts. Anything that moves outside of the engine.
Old 05-12-2011, 04:59 PM
Ya i've tried driving it with all the belts off. still makes the sound. I think it has something to do with the tranny or flexplate. I know when i was moving the engine into my shed to rebuild it that it fell on the flex plate in the dirt though so it wasn't bad. So maybe it bent or cracked it and i didn't see it. I tried having my wife hold it at 1500 rpm (where i can hear the noise the most) in the driveway today and i can't track down the noise at all under the hood or on the bell housing of the tranny ( listening with mechanic stethiscope) although inside the truck i can hear the noise. So i'm thinking it may be something hitting the body somewhere that i'm not seeing. Because i know i had a noise like that once before and it was my fuel filter tapping on the evaporator box. sounded just like a knock inside, but couldn't hear it outside the truck. Anyway i'm starting to calm down a little thinking this isn't a big deal, the only thing that really bothers me is that i've had an engine once that would make a noise very similiar to this at about 3000 rpm highway speed. and it turned out to be piston slap.
Old 05-12-2011, 08:30 PM
DoubleVision's Avatar
Torque converter bolts backing out is common. If your running headers and the bolts are new they too will back out until they get seasoned in or maybe you have a really light exhaust leak. Every SBC I`ve put together and there`s been many, All the ones I`ve built for myself either had a tick or a tap of some sort. I`ve built 5 for friends and none of them made any noises what so ever.
Old 05-12-2011, 08:52 PM
well just got done checking stuff, torque convertor bolts tight, tightened all exhaust bolts. Guess what i found? my friend (he's learning) bolted on the headers. and stripped out a bolt. I need i heard a pop when i was under the truck. I was like "you just broke one didn't you?" of course he said no no it's all good. well guess what, one of my bolts won't tighten now!! ha oh well easy fix. got a longer bolt in there and tightened her right up. didn't test drive it yet as the wife says it's time for bed, *wink* as for the noises, i feel you man, i just can't get a break. even when i'm not hearing noises, i'm imagining noises. anyway, i'll let yall know if the sound is gone now after i drive it tomorrow. hopefully so. if not i think i'm just gonna have to get louder exhaust.
Old 05-13-2011, 05:47 PM
alright well the noise is still there, still driving me crazy. i only have about a thousand miles on the motor so far, but everything seems to be going good except that dang noise lol. oh well i guess i'll just play it by ear and see if it changes. instead of tearing things down to chase casper.
Old 05-26-2011, 09:25 PM
so this knocking noise is still driving me crazy, although i've been trying not to let it do it. Still hoping it's nothing serious. Anyway, i've gathered more details now. it seems that once the engine reaches operating temp that the noise all but goes away, it's so faint that i may be just imagining it. but when the engine is cold at take off it is loudest, though even then it isn't really noticeable to anyone unless you really listen closely. next thing i found tonight was listening, with the truck in gear in the drive the noise is loudest at the number seven header pipe. only the pipe, if i listen at the head or around the header flange i can't even hear the noise, also i've listening at the bottom end all over the block, at the rear main seal, oil pan, nothing. the noise is definetly loudest at that one header pipe. any ideas guys?
Old 05-26-2011, 09:35 PM
techinspector1's Avatar
Wiki Edits: 326
If you're using header gaskets, the one where your....ahem....helper....broke the bolt off could have allowed the gases to cut the gasket at that spot and there is a divot in the gasket. No amount of tightening will help. Take the header loose and see if you have a solid gasket or not.
Old 05-26-2011, 10:00 PM
hmm i was kind of wondering if it could be a gasket leak. i am using the metal crush gaskets though i didn't really figure that it would eat them up if it was loose like it does the paper ones? i guess i can't know for sure until i pull it off and visually inspect it though.
ps: the bolt was on the end on number 7
406 sbc knocking noise at idle rotnrobbie Engine 3 03-21-2011 10:00 PM
humming noise from tranny mjkbj Transmission - Rearend 1 11-13-2005 08:56 AM
knocking noise during idle and full throttle 89camaroman Engine 8 10-18-2003 09:01 PM
Slow Acceleration, No Idle. bjam2 Engine 17 10-31-2002 07:59 PM
Won't idle, Slow acceleration bjam2 Engine 1 10-15-2002 06:08 PM
