-   Modern Electronic Engines (http://www.hotrodders.com/forum/modern-electronic-engines/)
-   -   slight misfire (http://www.hotrodders.com/forum/slight-misfire-210814.html)
Tom P. 12-22-2011 06:23 PM
slight misfire
My 2003 Mustang GT has a slight misfire. When I'm driving along at about any speed, the engine will occasionally stumble. I had the plugs replaced, as well as one ignition coil. I suspect the other coils may be weak and need to be replaced. Any recommendations as to what brand of coils to use?
LATECH 12-22-2011 06:43 PM
I have used brands from advanced and it has been OK. Some of the chrysler ones seem to be problematic.Other than that (I think it is BWD) they seem OK.
I am anal about quality for my own and would get NAPA or Ford(OEM) for my own.The customers seem to want to get out cheaply, so advanced it is for them.Most of the time ,like I said, it works out.
If you have a decent scanner, you can look at the misfire monitors for all 8 cylinders and it should give a clear indication of which one is acting up.
Also it may set a pending code(1 trip code) for the offending cylinder, which may help ID the culprit
sbchevfreak 12-24-2011 08:43 AM
On a Ford, OEM all the way. I have ran into problems with the quality consistency of aftermarket coils, especially where Ford is concerned for some reason.
