slight misfire - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 12-22-2011, 07:23 PM
slight misfire
My 2003 Mustang GT has a slight misfire. When I'm driving along at about any speed, the engine will occasionally stumble. I had the plugs replaced, as well as one ignition coil. I suspect the other coils may be weak and need to be replaced. Any recommendations as to what brand of coils to use?
Old 12-22-2011, 07:43 PM
LATECH's Avatar
I have used brands from advanced and it has been OK. Some of the chrysler ones seem to be problematic.Other than that (I think it is BWD) they seem OK.
I am anal about quality for my own and would get NAPA or Ford(OEM) for my own.The customers seem to want to get out cheaply, so advanced it is for them.Most of the time ,like I said, it works out.
If you have a decent scanner, you can look at the misfire monitors for all 8 cylinders and it should give a clear indication of which one is acting up.
Also it may set a pending code(1 trip code) for the offending cylinder, which may help ID the culprit
Old 12-24-2011, 09:43 AM
sbchevfreak's Avatar
Licenced Automotive Technician
On a Ford, OEM all the way. I have ran into problems with the quality consistency of aftermarket coils, especially where Ford is concerned for some reason.
Recent Modern Electronic Engines posts with photos
slight help...avatar mbbigboo Hotrodders Site Suggestions and Help 3 12-31-2010 12:49 PM
Slight vibration tuff82 Engine 5 07-05-2010 08:39 PM
slight hesitation at take off 406MOUSE Engine 1 04-30-2010 02:15 AM
460 slight build up FirstOnRaceDay11 Engine 5 04-13-2010 12:56 PM
Slight Exhaust screw up tc33 Engine 5 01-31-2009 08:30 PM
