Slight vibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2010, 08:11 AM
Slight vibration
Hi I got a 74 Camaro with a 355 and a 350 turbo tranny, i got a slight vibration at about 2000 rpm stopped or not, my exhaust is pretty much mounted solid due to the fact is lowered and I had to mount the exhaust pretty much solid, think that could be it?
Old 07-05-2010, 11:27 AM
SUX 2BU's Avatar
I don't have an answer for you but I too have a vibe at 2000 that I'm not sure of so I'm interested in hearing any replies about this.
Old 07-05-2010, 11:33 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You might want to re-check the harmonic balancer it might be loose.JMO
And are all the pulleys lined up properly also? and while you are at it check the converter bolts too. I had one do this and it had a busted bell-housing. All these things i have listed can cause this problem and i am sure someone else knows a few more things, JMO Is it a actual (VIBRATION) ?
Cole
Old 07-05-2010, 07:16 PM
Why would a broken belhousing cause a vibration, also why would misaligned pullys cause this? I forgot to mention that i feel it mostley when i let off the throttle, im really think its just the exhaust, the hangers just have a cheezy little rubber washer thats pretty much flat now cause i have them tight to the floor boards, i might install a set of flex pipes after the headers to isolate the engine
Old 07-05-2010, 07:38 PM
eloc431962's Avatar
Wiki Edits: 37
I meant warped pulley sorry about that, But i guarantee a busted bell will cause a vibration sitting still or driving. But anyway sounds like you already had it figured out i your original post. And yes it could possibly be the exhaust.
Really hard to tell without being there to feel the vibration. I was just throwing out a few things that can cause a slight vibration thats all.
Cole
Old 07-05-2010, 07:39 PM
awesome thanks man, prett shure its the exhaust, i cant even buge a pipe if I grab on to it, Price of looking good I guess
1987 S-10 driveline vibration thread. Tonyz2897 Transmission - Rearend 12 07-06-2010 04:17 PM
Mystery Vibration: long post Dano1972 Engine 6 06-20-2005 02:51 AM
Vibration at speed Doc68 Transmission - Rearend 141 01-22-2005 07:53 PM
Vehicle Vibration Smittyd55 Transmission - Rearend 3 03-01-2004 05:31 AM
drivetrain vibration catscan4free Transmission - Rearend 8 12-27-2003 03:43 PM
