Slight Vibration
Hi
I have a slight vibration going 30 MPH when engine is pulling. I have a 350 turbo auto trans. I dropped the drive shaft and discovered there is a 1/3/4 inch play where yoke goes in to trans tail piece. Is that enough play to cause a slight vibration? The drive shaft in the car looks new and has been balanced. Bob |
slight vibration
Can the clearance be less than 3/4 inch... say 1/2 inch?
Thats cutting it kinda close.. What suspension do you have?? Is there any signs on the slip yoke that it has went all the way in and bottomed out?
Do you have a hard time removing the shaft from the car ? |
slight vibration
yoke does not bottom out. Thats where i came up with a 1/3/4 " play.
Rear suspension is leaf springs and are pretty tight. |
| slight misfire | Tom P. | Modern Electronic Engines | 2 | 12-24-2011 08:43 AM |
| slight help...avatar | mbbigboo | Hotrodders Site Suggestions and Help | 3 | 12-31-2010 11:49 AM |
| Slight vibration | tuff82 | Engine | 5 | 07-05-2010 07:39 PM |
| slight hesitation at take off | 406MOUSE | Engine | 1 | 04-30-2010 01:15 AM |
| 700r4 slight bind on 2-3 | tnsmith10 | Transmission - Rearend | 4 | 11-16-2008 04:18 PM |
