slimming down - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2003, 07:50 PM
Red face slimming down
Does anyone know the dimensions for a rearend for pro-street when using the 33" Micky Thompsons when putting it under a '32 ford. Please let me know everything there is to know on this subject. By the way I'm looking for the measurement from hub to hub. Thanks,
Jeff :p
Old 04-25-2003, 05:06 AM
Post
The rim offset will determine the actual rear end width. If you are going to put everything UNDER the fenders.........You need the entire width to be 63-64 inches. That's the tires mounted on the rims, the wheels/ tires bolted to the rear axle assembly.
To figure this out, you MUST have the tires and rims already in your possession/mounted. Then put them standing like they are bolted to the rear axle and move them in/out until they are 63-63 inches apart overall and THEN measure the distance between the backside of the rims. This is the rear end width you need to put them under a Deuce.
