Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Slip on rocker panels
Old 11-15-2012, 07:35 PM
tech69 tech69 is offline
put up or shut up
yeah, I think the first two I ever did had that issue, especially the first one. I had a choice between not giving enough metal to the inner that sandwiches between the floor OR live with it not perfectly mated on the lower mating flange. The whole reason was cause I wanted to use the holes on the floor pan that I drilled to take it out. The replacement inner didn't account for the flange length needed to plug weld the holes in the floor, or factory spot welds I drilled out. Wasn't a huge deal but it was annoying.
