sliping tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2004, 07:41 PM
Checy_Guy's Avatar
sliping tranny
i have a th350 in my blazer and when its in 3rd and i floor it just revs up then pulls hard into gear. It also does it sometimes under WOT from 2nd to 3rd gear. anyone know what could cause this?
Chevy-Rules
Old 07-31-2004, 08:52 PM
mitmaks's Avatar
Last journal entry: Grille
is your kickdown linkage hooked up and adjusted properly and how about fluid? you wanna check it when running in neutral
Old 07-31-2004, 09:36 PM
Checy-Guy,
When was the last time the transmission was serviced?
Scholman
Old 08-01-2004, 02:36 AM
Checy_Guy's Avatar
well it came out of an old Monte and i put a stage 2 kit in it and a new filter so Ive never had it checked. it has worked fine for about 2 months now it just started. could the modulator be shot? i think that the tranny my be abit overfilled but not much it also has a tranny cooler.
Chevy-Rules
Old 08-01-2004, 09:31 PM
A bad modulator won't make it slip.
